| | | Forums66 Topics128,118 Posts1,056,305 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | This is for the 195? Chevy mutt. (My wife has named it Dumpy because we couldn't figure out how to keep the bed from going up when we loaded it.)
I'm not really sure that it has an SM 420 in it. It seems like it has a lot of gears, but the shift pattern is a big circle. Pushing the shift lever up only stops when your knuckles have impacted the dashboard, and pulling toward me the lever is stopped by the seat. I got it into reverse once (enough to back over a 4x4 chck anyway, but it seems like it was to the left and down. In my truck with the SM465 reverse is to the right and down.
Seriously, the shift pattern reminds me of a time when an airport crash crew left one of their water pumpers parked across our driveway so we could fix the radio. When it was time to go home I had to figure out which one of the four engines wasn't a pump engine, (Turned out that the drive engine was a Diesel and the other three were Chrysler 392 Hemis.) The gear shift moved around in a circle about 2 feet in diameter. I finally found a gear by pushing outwards, hard, while making the circle.
Is it possible that an SM 420 top cover could get into this condition?
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Sounds like years of shifting has taken it's toll on the shift rails and lever.Take the lever out at least and take a look inside.The covers are not too hard to rebuild if you can get the parts or replace the cover with a good used one.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | probably the Little pins in the top of the cover that fits the now worn out groves in the shifter. I replace the pins and weld up and re machine the groves.
Grigg | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Thanks, gtow69. Frankly, its so d***ed hot here that I'm stuck with looking at it longingly through the back door.
