3 members (UtahYork, 1955 1 Series, Forty9), 95 guests, and 5 robots.
Topics128,189
Posts1,057,222
Members48,465
#1542454 04/01/2024 11:19 PM
Crusing in the Passing Lane
When fitting a modern axle, the spring widths might not line up perfectly. A spacer can be used to hold a short spring bolt substitute that can be threaded or such into the spacer with a hole to fit the original spring bolt. Make sure the substitute bolt head is long enough if angle shims are to be inserted to correct pinion angle.
In this case a Dana C Blue Bird rear axle with disc brakes and 10 on 7.25” bolt pattern was fitted to a ‘52 GMC 280.
Ed
Ed, does this apply to just Big Bolts, or can this work for smaller trucks too??? Since this topic is really driveline related, it's been moved to the Driveline forum. wink
~ Dan
1951 Chevy 3 window 3100
Common sense would suggest that the size of the truck makes no difference, as long as the end result is achieved. Offsetting the center bolt hole takes a lot less effort than trying to reposition the spring pads on an axle tube, even if a spacer beside the U bolts might also be needed to eliminate any sideways strain on the centering pin.
