3 members (55shaker, 3B, 1 invisible),
144
Mod | | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 75 New Guy | | New Guy Joined: Dec 2006 Posts: 75 | I have a 63 1800 Loadstar that the unite leaks oil are there more than one kind of PS unites for these trucks? Also have a 74 IH 1700 Loadstar & want to put PS in it, Are these unites the same? Do the frames have the bolt holes for PS even if ther was no PS in them from the factory? I have a pump for a PS unite but are the mounts diff on a 345 & a 392 Cu-In? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think the mounts are the same for the pump, but not sure.
I also think the frame is drilled for either steering gear box. I just worked on a friends 76 1600, and we were talking about all the holes in the frame, must be for many different options and configurations, so fewer frames needed to be stocked.
Grigg | | |
