0 members (), 79 guests, and 1 robot.
Topics128,195
Posts1,057,374
Members48,469
Looking for ideas of where to locate a battery disconnect switch. Thought about in the kick panel that sticks up under the seat. Facing towards the floor shifter. Kind of concerned about sparks near the tank which is still in the cab. The red part is a key that is removed when the switch is off.
Thanks for any ideas
Jeff
1964 Chevrolet K10 Fleetside
"A Kid's First Truck"
Follow in the DITY
1951 Chevrolet 3100
Follow his build in the Project Journals
1969 Chevrolet Camaro Convertible | 2020 Chevrolet Silverado | 3500 Duramax | 2021 GMC Sierra Denali
USAF Veteran 1983-1987 | PSP retired 1990- 2012
I connected mine directly to the ground terminal on the battery. (Green knob disconnect type)
Where is your battery located?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
It is in the stock location on the right hand frame rail under the cab.
Jeff
Follow in the DITY
1951 Chevrolet 3100
I did this as well. In a floor mount battery. It’s just my custom to disconnect each time I put the truck away. I don’t have high levels of trust in the wiring and this works fine for my needs.
I suspect the OP is looking for a more convenient option. Perhaps as much for anti-theft as for fire prevention.
Personally, I don’t see what is wrong with the OPs seat mount idea. As long as it’s wired carefully and cables are protected from abrasion….I wouldn’t think sparks would be a risk.
1951 3100
Good luck with that disconnect switch- - - -it only has about one fourth the current capacity necessary for carrying full starter cranking current. It will burn out quickly, or at least result in low cranking speed and poor starting. You need a 500 amp minimum capacity, and one with a 1K amp surge capacity is better.
https://www.oreillyauto.com/detail/...aster-disconnect-switch/ch00/2484?pos=11
From my google research that is rated for 100amp continuous and 200amp max for the one Original poster crummy posted
and 175A continuous, 800A intermittent for the Oreilly one Jerry(hotrod) posted.
for those of you that don't want to look it up separately.
I might have to agree with Jerry. The terminals on that switch look a little small. But not knowing the specifications on Crummy's switch, it might work just fine. The biggest issue with switches (or relays) and their rating is the ability to disconnect with power across them, which isn't really an issue with a battery disconnect as you wouldn't normally disconnect with the starter engaged. But it's something that needs to be paid attention to.
[on edit] looks like hcb3200 got there first with the correct info. thumbs_up
Another thing to point out is to be sure to provide some protection for the cables where they go through the sheet metal of the floor. Use a grommet or a nice thick sleeve around the cables - especially if you're bringing the positive cable thru the switch. Doesn't matter quite as much on the ground cable, but still good practice.
Anyone have any luck with this remote style of battery disconnect or simular? No holes to drill just attach it to the neg post of the battery. This one says that it is rated for 240 amps continuous and 1200amp peak.
https://a.co/d/f1DNlWrRemote Battery Switch
1954 GMC Series 1
102-24 Series 1/2 Ton Long Bed
248 to a Hydramatic
Gimmicks like that are known as a P.T. Barnum Special- - - - -"There's one born every minute!" Can you imagine having to remove that one wnen it fails late at night in sub-zero weather? Or even if the battery in the remote goes dead at an inopportune time?
I will take Jerrys advise. I may try to see if my local NAPA has something similar. Not many Oreilly's in my neck of the Woods. If NAPA can't help me then I will order online from Oreilly's. And yes, I am looking for something discreet and easily accessible mostly for anti theft purposes and or to disconnect when in storage. My plan is to drive this often and sometimes out of the area with over night stays. So a disconnect with give me a little piece of mind. big_eek
What about under the seat in the kick panel for placing it? I will also look at catalog from my Jayco dealer. Just remembered my camper has a large battery disconnect in it.
Jeff
Follow in the DITY
1951 Chevrolet 3100
Another option is a heavy duty relay that's energized by a small toggle switch when you want to run the truck. The downside is the relay would need to be heavy duty enough to stay energized while driving, and the control switch would need to always be energized (and fused.) You could put the toggle switch in a concealed location under the dash and the relay on the frame near the battery.
Or if you aren't too worried about battery discharge, and just want added security, you could intercept the power feed to the ignition switch with a concealed switch. It would still crank from the stomp starter, but wouldn't start or run.
A quick way to make the switch I recommended a little more difficult to operate for anti theft purposes is to simply remove the handle. It's a slip fit over the shaft, retained by a screw. Just flip the switch to the "off" position, lift the handle off the shaft, and put it into your pocket. Without the retainer screw, it's a field-expedient "key". A potential car thief would have to have pliers or a vise grip handy to turn the shaft, after locating the cutoff.
Here's an Ebay ad for a NASCAR certified 300/1000 amp switch- - - -same one we used on the round track race cars we built.
www.ebay.com/itm/266135305991?
Cole Hersee has been our fleet standard for as long as I've worked at the company. Maybe even longer. I'm working on my 40th year.
Better than removing the handle as Jerry suggested, would be to get the keyed version. We used to call them "Cat" keys because they were on all of our yellow fleet and most of that equipment stayed out in the field. Can't remember any of our machines being stolen, vandalized, yes. But not stolen. Neat little duck bill shape.
Maybe place up on the inner fender where you would need to reach up over the tire assembly to operate. If it ain't easy for you, it won't be easy for the thief!
