1 members (JW51), 56 guests, and 0 robots.
Topics128,080
Posts1,055,945
Members48,430
Anyone know how thick oem is. I made some out of convayer belt but my pedals are not centered in cab floor. Thinking I need thicker pads. Thanks
The FAM (Section 1, Sheet 3.09) says shim as required so there's 1.83 +.06/-.00 inches between the bottom of the floor and the top of the frame. You could add more conveyor belt if you're below that amount.
Thanks. I'm at roughly 1.750 so I'll add another homeade puck. Should be alot closer.
