1 members (Charles in CA),
66
Mod | | | Forums66 Topics128,187 Posts1,057,214 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 2,493 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,493 | Depends on whether you have a 6v or 12v electrical system.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Oct 2021 Posts: 6,957 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,957 |
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Oct 2021 Posts: 6,957 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,957 | Or should I have asked what watt/candle power is specified.
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Close enough and with enough pressure you can blow a hole in almost anything. I'm usually running about 75 PSI and use a generic rubber-tipped air nozzle and squirt air from about a foot or so away. I clean the shop vac filter that way too. The specs on paper filters are for AVERAGE pore size, which means that there are pores that are considerably larger. Try looking through a K&N filter after you've cleaned and oiled it. You can see the light coming through the holes like it was a dry shake roof. If you see those holes in your paper filter, throw it away. And for pet's sake don't use the HRL disposal method in fire season. All this discussion is why I prefer oil bath air cleaners, mostly I'm cheap and they work fine.
When Mt. St. Helens blew its top forty years ago, the state patrol cars got retrofitted with big, external-mounted truck air filters with cyclone elements to spin out the dust before it went into the filter. These were mounted on the front bumper with what looked like dryer-vent hose going to the carburetor. The civilian cars with only the factory paper filters died a terrible death and ended up in wrecking yards in short order. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Oct 2021 Posts: 6,957 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,957 | Wow, That was pretty foresighted of the head mechanic at the State Patrol.
| | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | I wonder how big an increase there was in their speeding ticket and DUI quotas to pay for those fancy air cleaners? Jerry
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Things were such a mess downwind of the volcano that very few people were on the road. There was ash inches deep allover everything all the way past Spokane, 300 miles away. Headlights on all day. The acid rain etched the new paint on my 50 Stude and on my 51 Chev pickup which were both parked outside in Seattle. I drove neither till the dust settled. Rode my bicycle to work at the Saab dealer where we did a land office business changing air filters and then engine overhauls. Old Saab 95 and 96 had oil bath air cleaners and seemed to fare better, though maybe it was the Ford industrial V4 engines were better. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | One side effect of the dust that settled- - - - -ceramics hobbyists and pottery businesses discovered that it made some of the best quality pottery glazing material they had ever used. There was a big business for quite a while, collecting the volcanic ash and selling it to pottery shops. Jerry
