| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 28 Apprentice | | Apprentice Joined: Apr 2007 Posts: 28 | Need some advice on my 54 chevy 1 ton
I was thinking about putting shocks on the truck. Has anyone tried doing this?
Itried a search and didnt see anything
or am i just wasting my time | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I had shocks on the front of my 52 1 ton, and I think they helped. Never had any on the rear, and occasionally I thought they would help.
I don't plan to install them on my 2 ton right now. Although that could change down the road. I will look into front and rear sway bars for the 2 ton.
Grigg | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | I've been interested in sway bars even though they effectively increase spring stiffness. Is it safe to assume that what works on your 2 ton will work on a 51 4400?
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes, the frames are nearly identical between the 4400 and 6400, the later being made of thicker metal. My axles are not original, but should be close enough that whatever I do for sway bars will work on an original truck too.
Grigg | | |
