8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL), 100 guests, and 2 robots.
Topics128,070
Posts1,055,892
Members48,428
Had all the stuff laying around so went ahead and put it on. Didn't think it was working. Only putting out 12.17 volts. But from what I've researched that's correct for no load. Anyhow I have a 12 volt blower motor on the heater so fired that up .14.3 volts. Woo hoo I'm charging.
So I've searched but have not had much luck finding replacement bulb numbers for 12 volt. Anyone have these numbers.
I do have double bulbs in the rear. One for brakes another for markers. So need two different candle power.
Moderator, Electrical Bay
As I recall 1157LL is the dual filament clear bulb (tail/brake) for 12v.
~ Jon
Correct. But I have 2 single element sockets in each housing.
I think 1156 should work,and if you need front signal or parking lites they come in amber also 1156a
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
1156 bulbs are 28W. If you need single contact bulbs that aren't as bright, 1003 bulbs (same socket) are 12W.
FYI replacement bulb numbers for 12 volt
Instrument bulbs #1895N
Parking lights #67
Dome light #1141
Headlight H6024
If you have the double socket bulbs I ordered a 1155 led from Amazon for the brake light. They are smaller like the #67
I will add picture of brake light bulb
