1 members (Otto Skorzeny), 330 guests, and 5 robots.
Topics128,162
Posts1,057,068
Members48,463
24601
24601
Hey gang, it's just about time to re-awaken our sleeping beauties from their winter hibernation .... But ... ooopsies! Did someone leave the lights on when they parked it last November and now they have a dead battery???
Good thing we just put together a new Tech Tip on reviving dead batteries!
Yes, sometimes dead is dead. But ... sometimes it isn't ...
chug
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Moderator
Moderator
2 Offline
Good write up John! Jerry’s knowledge is unlimited in my mind! Gordon and many others rate right up there also.
You and Peggy have united all that knowledge here on the Bolt.
Don
Edit: Headed to the shop right now and try it out.
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
24601
24601
I'm trying it, as I work on the '49 turn signal project, on a battery that's been sitting in the shop for 4 or 5 years. I don't remember where it came from. The date on it is 2014. I can charge it up to about 12.5. I'm using a high wattage off road light to discharge it -- early on, it took about 35 seconds to drop to about 8 volts (where the light went out). I have a test light on it now for a slower, longer discharge. We're at charge/discharge cycle 5 at the moment. Going for 10. We'll see if we can bring this one back.
Would putting new electrolyte in it help?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Add a little electrolyte, but don't overload it- - - -a couple of ounces per cell should be about tops. Once the sulfate crystals start to redissolve, you'll end up with acid that's too strong if you disturb the chemical balance. "Full charge" specific gravity on an open cell battery should be around 1.265. Anywhere above a 1.250 specific gravity reading (on all the cells) is sufficient to do a high rate discharge test. A battery hydrometer to check the concentration of the acid is pretty much a "must have" tool when charging and testing open cell batteries. You don't have that option with a saealed top battery. A "discharged" battery will have an electrolyte specific gravity of 1.000- - - - -plain water. All the sulfuric acid has been absorbed by the cell plates.
www.ebay.com/itm/133780975826?
