4 members (DadsFirstPickup, Gray_Ghost, cspecken, 1 invisible), 178 guests, and 5 robots.
Topics128,087
Posts1,056,112
Members48,434
#1538785 03/03/2024 2:03 PM
While fixing a leaking valve cover discovered there isn't a tube in the center going back over top.it is plugged. See picture. Is this ok? Thanks, Grady.
1949 3100
Old Blue
GradyB, A peek into a couple of Chevy Master books (1929-46 and 1929-53) shows the original oil connector to be GM# 838217 for 1937-39 engines. Below is a snapshot snagged form an NOS one being offered to give a visual on what it looked like out of the box. IIRC, the removal of the overflow tube/plugging of the port was often done to increase oil flow to the rocker shafts and rockers. If you are getting good oiling up there, it shouldn't be a problem IMO.
Others with more knowledge/experience will chime in soon I am sure. wink
~ Dan
1951 Chevy 3 window 3100
Thanks for info. I have 2 othere heads with them on but are newer heads but if it's getting the oil to rockers I'll just let it be.
1949 3100
Old Blue
It was common practice back in the day to cut the tubing and crimp it off. More oil to the rockers yes, but also increased engine oil pressure by a few pounds. Of all the rockers I have seen over the years, only a few had not been crimped.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
The only downside is possibly oil consumption due to excessive oil getting to the valves, and difficulty keeping the valve cover gaskets from leaking.
My Blog
