| | | Forums66 Topics128,193 Posts1,057,238 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 19 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 19 | I'm looking at buying a really nice 58 Chevy 60 series truck. It's a 1 1/2 ton truck. Are the cabs on these big trucks the same as a pickup?? Also it has a 261 engine that has a bad rod bearing. Are the heads on the 261's the same as the 235's, or is the 261 a completely different engine?? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes on the cabs all being the same - can't say about the heads
Bill | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | If it's a 60 series, it's a 2 ton. Cab is the same, except in the floor area, around the transmission. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dlhenk, A 261 is a bored out 235 basically, it was an old hot rod trick to put the head off of a 235 on a 261, it gave you a higer compression ratio, and hence more power. A 261 is the largest displacement engine that will "bolt in" where any 216, or 235 was, making them a much sought after engine for upgrade purposes, hope that helps. | | | | | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | I believe in the archives somewhere this question was asked before and the 261 block has a couple of (steam holes?) that the 235 doesn't have and you can drill those extra couple of holes by using the 261 head gasket as a template to drill the holes in the head. Try the search at top of page. Hope this helps. | | |
