5 members (klhansen, Otto Skorzeny, TUTS 59, dt235sd, 1 invisible), 146 guests, and 3 robots.
Topics128,095
Posts1,056,480
Members48,444
Making room for 235 with stock waterpump. Yes I know there's a plate to do this also. But I wanted to do it this way. Also dropped down about 1 1/2" . Not done yet but going good. Stock radiator probably would have tucked underneath latch plate but this aftermarket radiator was 2" taller. Ordered for the truck and this is what I got. Must be heavy duty?
Insomniac
Insomniac
Moving the rad forward seems like a common alternative to installing an adapter plate and changing the pump. This one was done long before the adapter plate was available.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Pretty much back together. No coolant yet and have to put fan back on. I'm pooped for sure. Tomorrow back to job so I can rest.
