5 members (Tronman, G508, Otto Skorzeny, Peggy M, 1 invisible), 75 guests, and 1 robot.
Topics128,026
Posts1,055,410
Members48,422
#1537035 02/18/2024 12:17 AM
I put the u joint back in the 54 GMC today and was curious as to if it was worn as the two caps that are held in by the c clips slid in without a press ,Once the clips are in it cannot come out but the caps move inward .There is no play but on some of the videos I seen a press is used to get them out .I have a spare joint that is in the yoke and I cannot move the caps .The u joint is not new but shows no wear .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
KEVINSKI #1537053 02/18/2024 5:26 AM
I had a u-joint once on my F250 that I could press the cups into the yoke with my thumbs. I wound up replacing the yoke. Not sure about a 54 GMC, but I think they should be a press fit.
KEVINSKI #1537055 02/18/2024 9:26 AM
Of the hundred or so u joints I have replaced on farm machinery drivelines of all kinds and sizes, I never ran into one that didn't need some type of pressure to repair. Some only required a hammer and proper-sized socket to drive out, some needed to be pressed out but none needed thumb pressure only.
The longevity of that joint would be suspect to me. Sure, it may be held in place by the clips but there is bound to be play, however imperceptible it may be, which will eventually cause that joint to fail, probably at the most inopportune moment.
Or, one could use the hired-hand approach... "Oh, I reckon it'll be alright."
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
KEVINSKI #1537058 02/18/2024 12:28 PM
Thanks good imfo I will take it out before I go farther ,to bad I did not think of it before I bent the tangs over but better now than later .
"The Journey"
Follow in the DITY
Jethro in Va #1537197 02/19/2024 6:43 AM
That's why God in invent balin' wire!
BC
1960 C60 pasture art
KEVINSKI #1537426 02/20/2024 9:53 PM
Swapped out the u joint and noticed the u joint has a grove on the one side ,looks like for oil ,now does it matter which way the u joint faces .
"The Journey"
Follow in the DITY
KEVINSKI #1537428 02/20/2024 10:04 PM
I doubt it matters whether the grooves go toward the front or back. The oil is going to get in there no matter what. I don't recall the replacement u-joint I got had those grooves.
KEVINSKI #1537462 02/21/2024 2:16 AM
Thanks I did not think so either but thought I would see what others thought .Kevin
"The Journey"
Follow in the DITY
