0 members (),
130
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,186 Posts1,057,307 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 282 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 282 | I'm going to a town that has a Tractor Supply store on Saturday. I have read many times the discussions about corn head grease. The tractor supply store has a product that I want your opinion on. It is: Super S Cotton Picker Spindle Grease 00. would this be a good product for my 47 Chevy truck? I'm currently using 90wt gear oil. My shaft does not leak but the lock nut leaks a little bit. I'll address that soon. Just thinking of replacing with something more appropriate.
1947 3600 Chevy
| | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | 00 grease is good. Corn head grease is not self-leveling...which is what your steering box was designed to use. I mix corn head grease about 50/50 with 90 weight oil to get a blend that is thicker than plain 90 weight but is still self-leveling. If you can't pour the grease you're using into your steering box then it is probably too thick to be a good choice. Good luck. I bought the last corn head grease (believe it or not on another forum a fellow refers to it as corn bread grease) at the John Deere store.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Oct 2021 Posts: 6,963 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,963 | How do you empty what's already in there? My truck didn't have a cover on it when I got it and I'd like to clean it out.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Oct 2019 Posts: 421 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 421 | Would the 00 Grease from NAPA be good for the steering box without the corn head grease? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes 00 grease was specified. Tractor SupplySuper S Cotton Picker Spindle Grease 00 - Cornhead 00 Grease
| | | | | Joined: Feb 2001 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 41 | Here goes. 00 grease is self leveling. JD cornhead grease uses a polyurea soap thickener. Super S (TSC) OO is Lithium complex soap based. Polyurea is good but is not compatible with lithium. If you remove the gearbox and clean it out, Polyurea is ok. Most automotive greases are lithium based. Read the label, tag your gearbox. The foundry I worked in used 3 or 4 different grease types. You have to keep them separate. | | | | | Joined: Nov 2023 Posts: 283 'Bolter | | 'Bolter Joined: Nov 2023 Posts: 283 | Never tried this but I had a guy tell me to use STP in the steering box. Uses it on all his old tractors and trucks. According to him tightens thing right up. But slippery enough that it doesn't binde things up. Just a thought | | | | | Joined: May 2015 Posts: 11,176 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,176 | I’m not sure I’d use STP in a steering gear. Especially where I live. I use it once in a Model A transmission and one morning when it got below freezing I nearly bent the shift lever trying to shift gears. It would be like anti-power steering in a steering box.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2020 Posts: 282 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 282 | Stan58, so the Super S 00 grease should be compatible with the automotive grease & oils used in our trucks? I picked up two quarts and I'll look into it on Monday, as far as self-leveling and such. It does seem like it is a thick oil type product and comes in a squeeze bottle.
1947 3600 Chevy
| | | | | Joined: Nov 2021 Posts: 1,405 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,405 | I'm following along as I am intending to use the Tractor Supply 00 Grease in my gear box. | | | | | Joined: Feb 2019 Posts: 4,513 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,513 | I put Super S Cotton Picker Spindle Grease 00 from Tractor Supply in my truck several years ago. It works well, doesn’t leak and it’s less than seven dollars a quart! You can’t go wrong.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2001 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 41 | As long as the John Deere grease isn’t in there. | | | | | Joined: Feb 2001 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 41 | 00 grease used to be used on a lot of industrial applications when seals were labyrinth or felt. Hardly used now. Industry has been going to lighter and lighter oils, with tighter clearances. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I have Tractor Supply 00 in two of my old Willys Jeeps and I think it work fine. Do a test to satisfy yourself, put a small amount in a little Dixie cup and then take a spoonful out...does it leave a hole or does it level itself back out? You can also put it in the freezer and try the test again later if you live in a cold climate. Mike B  | | | | | Joined: Feb 2023 Posts: 103 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 103 | Has anyone tried Castrol Shl 00 Grease or Prime Line Premium '00' Grease both available from NAPA Canada?
1954 Chevy 1300 engine 235 (1959) 1955 (first series) Chevy 3100 engine 261 (1957) 1927 (other brand) Model T- engine 327 (1968)
| | | | | Joined: Feb 2001 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 41 | Both look to be lithium complex 00 semi fluid greases. Should be good. Used in big truck hubs. | | | | | Joined: Nov 2021 Posts: 1,405 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,405 | Added the Tractor Supply 00 grease to my steering gear today. A little hard to tell if it is full so I will check it after the added grease has a few days to settle. | | |
