3 members (delwrench, UtahYork, 1 invisible), 149 guests, and 2 robots.
Topics128,077
Posts1,056,280
Members48,441
Ok, so new here, have a question. Rebuilding a 1950 Chevy 3100 and it came with inner door window trim rings off. They have a handful of screw holes in them and am not sure how the get attached to the door, there are no screw holes in the door though. I did buy new window channels that are plastic and felt. Do these actually screw or rivet to the plastic window channel inserts or am I missing something or are they the wrong trim rings?
Found the holes
Can you post pictures of the inner trim and your door?
I can check my 1950 3100 in the morning. I know it should be a few Phillips head screws that hold it.
And I'm guessing pre-drilled in the door itself. Hopefully an expert will confirm this.
See attached picture to confirm inner trim piece.
Todd
1950 Chevy 3100
My door has screw holes for the inside trim screws but it also has all the window related seal material removed for paint/refurbishing. Is it possible that the screw holes are being hidden by the window seal?
1949/50 3600 Project
Follow in Project Journals
That trim looks just like mine but I don’t see where on the door it screws to, does it screw to the replacement channel?
Lay the trim in place. Get a flashlight, look through the screw hole. The screws go pretty far up in there. Sometimes, I'll use an awl to locate the hole and try to duplicate the awl angle when I go to install the screw.
Thanks all for the replies, I finally went out there and looked at in the daylight and now I see the screw holes. Makes more sense now 🥴 I will add a photo to my original post too…
Ok, see pictures attached. 7 screws. 2 left 2 right and 3 top.
Todd
All good, you got it now!
1950 Chevy 3100
Appreciate the response, I did find the holes. And posted pics of mine. Do you happen to know what size those screws are?
Dogdaddy, I do not know the size. Hopefully someone will let you know.
Todd
1950 Chevy 3100
Looks like all the vendors sell them.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
I use a 4" length of 1/16" steel tig wire as a guide to figure out what angle I need to start the screws.
Tig wire is very straight and very stiff which helps for maneuvering the trim to match the alignment with the hole.
I believe the OEM screw was a #8 size. If you need to go up a size because of wallered out holes, they do make a #10 screw with a #8 head.
