5 members (Otto Skorzeny, Biermann, Ridgeback, Oswald, GMCJammer51), 72 guests, and 1 robot.
Topics128,154
Posts1,056,837
Members48,456
I
Moderated
Moderated
I Offline
I have a 53 3100 which has been fitted with a '57 235, with a 4 speed box (Are they all 4 speeds?). It was imported without a flywheel cover on the gearbox. Is this a particular cover for that trans, or will a generic type automatic trans cover fit (T350, etc) ? I am having a hard time getting any info on this, and being in Australia, no-one carries one of these. I have tried Rock auto and a couple of others, but no dice.
O Online: Content
Three speed, four speed, and automatic transmissions were offered. I doubt that a cover for an automatic will fit.
1950 Chevrolet 3100 (Ol' Roy)
3B Offline
Hy Ivanz, the cover for the 53 standard transmission bellhousing should fit. I'm assuming they used the 53 bellhousing when they swapped the 57 engine into place, as the mount on the 57 bellhousing are of a different design not compatible with the 53 rear engine crossmember, hope that helps.
I haven’t see any vendors offering a 6cyl cover for the 2nd series trucks. The Truck Shop in Orange, CA advertises a plastic cover for the V8. I have purchased 6cyl parts from them that are not listed in their catalog. (They told me that their catalog is outdated.) It won’t hurt to reach out and ask if they offer a cover for the 6cyl. See lower left of attached photo.
http://www.truckandcarshop.com/
Good luck.
1955 Chevy 2nd Series 3100 Stepside, 235cid
It would probably be simpler to have a local sheet metal shop fabricate a cover. There's nothing particularly important about its function except to protect the rotating parts from catching gravel or road debris and jamming it up into the bell housing. A reasonably competent tin bender could probably bang one out in a couple of hours. A piece of air conditioning duct work, a pair of tin snips, and a few pop rivets would be all I'd need to make a suitable cover.
I
Moderated
Moderated
I Offline
I can only assume they used the '53 bellhousing, so that is what I will look for. I don't want to use the Car & truck shop, as they won't help if you are calling from overseas! I have tried several times to contact/phone them so I gave up. I may have to chop up and modify something available locally.
The Filling Station
The Filling Station
Just for other people who may look up this thread in the future, that 838438 GM part number that the Filling Station listing in the post above also fits GMC 1939-1953 "ALL" (models 350 or smaller), but not 55.2-60. I don't have 54-55.1 documentation.
