6 members (Gdads51, Hambone, TUTS 59, Otto Skorzeny, Guitplayer, Gray_Ghost), 101 guests, and 2 robots.
Topics128,084
Posts1,056,087
Members48,434
#1534699 01/29/2024 9:59 PM
Working on 50 truck 3100 4 speed. I was thinking about changing rear end and making it open driveshaft.What do I need to do to make my transmission open drive? Thanks in advance, Rick
All you need to do is change the rear bearing retainer for the open driveline type, and install an open drive output flange. The transmissions ahead of the bearing retainer are identical.
Thanks Jerry, where might I find these parts?
Place an Ad here in the Parts Wanted section, look on eBay, Craig's List or Facebook Market Place, you won't find it new anywhere. It might be cheaper to buy a complete transmission, look for one from 1955 and newer. You'll also need the U-joint flange plate that bolts to the output shaft so you can have a drive shaft made.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
