Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (TUTS 59, DES57, BLUEMEANIE, Peggy M, Waveski, 55shaker, Joe W), 532 guests, and 1 robot.
Topics126,777
Posts1,039,282
Members48,100
Most Online2,175
Jul 21st, 2025
#1534654 01/29/2024 5:00 PM
Red
Offline
Would I have any issues using a 1950 0-30lbs Oil pressure gauge with a 1954 235 Chevrolet engine. The engine was holding over 40lbs while testing on a portable stand. Just asking before I purchase 0-60lbs gauge.
Thanks Red
1950 5 Window
Red #1534655 01/29/2024 5:05 PM
7
7 Offline
Analog gauges are designed to be most accurate at mid-gauge. If the 30 lb. gauge is pegged on start-up and cold oil, it will probably affect the accuracy from that point on. I would run a 60 lb. gauge
Red #1534658 01/29/2024 5:24 PM
+1 on the 60# gauge. Hot idle with good rod and main bearings should probably be somewhere in the 20+ pound range, depending on the weight oil you're running, and a little higher at highway cruise RPM. A GMC gauge has a 0-60 pound range, and will fit the original dash cluster.
Red #1534661 01/29/2024 5:36 PM
Two of my trucks came with stock 30# oil pressure gauges ('42 and '50 COE) and replacement 1958 235 engines. Clearly, it would be best to use a 60# gauge, but who makes such a gauge for a '42 cluster? Both trucks pin the gauges on startup and register 20-25# on hot idle. Pinning the gauge does not seem to affect or damage the gauges as I have been running the '42 that way for 30+ years and the ''50 for 15 years. In essence, the gauges act sort of like oil pressure warning lights. They would only help if the oil pressure is too low.
Red, either way works. I would do whatever fits your budget and your plans for your truck.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Red #1534662 01/29/2024 6:02 PM
Red
Offline
Thank You
1950 5 Window
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.713s Queries: 14 (0.056s) Memory: 0.6102 MB (Peak: 0.6569 MB) Data Comp: Zlib Server Time: 2025-09-22 17:05:29 UTC
Valid HTML 5 and Valid CSS
