5 members (TooMany2count, 1955 1 Series, Mike B, klhansen, Otto Skorzeny), 135 guests, and 3 robots.
Topics128,123
Posts1,056,653
Members48,450
#1534481 01/28/2024 1:39 AM
Hi guys,
Could use some advice on a GMC 228 exhaust manifold I purchased on eBay. I cleaned it up and found the mount flanges considerably corroded (see attached photos). Can these faces be machined to clean up? If needed can they be weld repaired to build up the faces, then be machined?
Thank you for any input.
A machine shop where I worked part time had a BIG belt sander- - - -like 12" wide and over 3 feet long. We would use it to clean up manifold flanges like that. It would also be possible to set it up on a mill like a Blockmaster and machine the pits away. As long as there's a little bit of the flange standing proud of the manifold runners, you'll be good to go.
O Online: Content
I recently repaired a '56 Cadillac exhaust manifold in worse shape than that by taking off just enough to get all the ports smooth and in the same plane. A little bit of Yale Muffler Cement between the manifold and gasket on areas that are too deeply pitted to machine out works wonders, too.
1950 Chevrolet 3100 (Ol' Roy)
If you are going to repair that exhaust manifold, loose mount it and the intake manifold to the head (don't forget the alignment rings in the intake ports) with an 838290 gasket (Victor # 17473, old Chevy six engines use the same part) between the two manifolds. Once you get all the bolts snug (but not tight) tighten up the intake to exhaust bolts and then remove the manifolds as one piece. Take the assembly to the machine shop and have them make the surface of both manifolds flat and in the same plane at the same time.
Ask me how I know.
