Those might be a bit too wide if you're using the stock 4.5" wide 16" wheels. 215 85 16 seems to be a choice that other 'bolters have used. I bought some 6.50-16 tires for my truck.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
The Firestones on my truck are 215/70x16. I would have preferred the 225/85x16 because they're quite close to the original tire dimensions. I have that size on my Packard with 4.5" rims and they perfectly fill the wheel well. The price difference was too great to justify their purchase , however. These Firestones were $94 each on Amazon.
The 215/85x16 tires will be about 1 1/4"" or so taller sidewall than these. That translates to about 2 1/2" in diameter larger.
1950 Chevrolet 3100 (Ol' Roy)
MNSmith - thanks for the web sites - I will be looking at them later in the year when I am looking for wheels and tires for my 3600. I would like to stay in the range of the 34.5" outside diamter of the tires that are on the truck now to work with my transmission/rear axle ratios.
