1 members (baldeagle),
87
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | I'm considering trying some chrome vinyl wrap, the fender spears on my '57 5700 LCF are pitted and dull, I really don't think I would ever find any that are in good shape. I haven't checked pricing or available re-chrome service but probably out of reach financially. Has anyone here used chrome vinyl wrap?
| | | | | Joined: Nov 1995 Posts: 5,713 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,713 | Hopefully, someone will have some recent real world (automotive) experience to share with you.
Sounds interesting. I hope the technology has improved since when I was part of a team evaluating it as an aircraft paint alternative about 20 years ago ... (it didn't work ...)
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2007 Posts: 3,371 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,371 | I have seen the chrome vinyl wrap used on bumpers, those are mostly smooth and Flat. The problem with a wrap is that it scars easily. Another thought may be to have your emblems powder coated. I have a friend who does this. He used a chrome powder from Eastwood to cover the center caps on my 4x4's wheels. They look great and hold up well.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | I got a grill chrome vinyl wrapped on a J2000 a few years back. It looked fantastic until I hit a few bugs and tried to clean it.
The color/surface finish degraded extremely rapidly and then it looked worse than the pre-wrap condition.
I second the recommendation for powdercoating. The chrome powder from Eastwood looks really good and is plenty durable as long as you put a clear over it. It won't look as good as getting it rechromed, but it is the next best thing.
Edit: I checked my notes and "a few years" was 2.5.
| | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | Thank you all for the replies, I didn't think of powder coat since I'm not a big fan of it. Here in the rust belt the powder coat is like a plastic envelope, it traps and holds water/salt/lime slurry and the metal rots away. The fender spears would certainly be out of harms way, I'll put some thought into that.
| | | | | Joined: Oct 2021 Posts: 6,687 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,687 | What? Powder coat isn't any more prone to rust than paint. In fact it's better because it's a lot more resistant to chips and flakes.
Meanwhile, vinyl wrap is the very definition of an envelope.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | I agree that powder coat is tough and not affected by rust, my point being that the tough powder coat film does not break down, it stays intact and if water gets in behind it, the metal fails. Paint can do similar but typically the paint film will fail in smaller pieces and start to lose their bond, exposing the oxidation sooner than the powder coat item. I'm only relating my experience with aftermarket coated items such as trailer hitches, running boards, etc.
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | I'm with 78buckshot. I've had powder coated items peel in giant flakes. They get a little chip, then the rust grows underneath the coating, loosening it in big chunks. If it can be protected from chips (I'd think something like a front bumper would be especially vulnerable) then it might be the way to go. Same issue with vinyl wrap, which I may try on a rear bumper.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
