Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (TUTS 59, BLUEMEANIE, DES57, Peggy M, Waveski), 534 guests, and 1 robot.
Topics126,777
Posts1,039,282
Members48,100
Most Online2,175
Jul 21st, 2025
#1533899 01/23/2024 6:03 PM
Red
Offline
Oil filter canister for a 1954 Chevrolet 235, series SC-653. I have lost the spring that goes inside this unit. Is this spring absolutley necessary, and any suggestions for replacement spring. Second question, the oil line from the block to the oil filter canister, does it require an in line fitting that reduces the oil flow to the canister?
Thanks Red.
1950 5 Window
Red #1533908 01/23/2024 6:52 PM
Yes. I believe it's a 1/8" inlet. The spring keeps the filter element in place. Any spring that fits will work.
1950 Chevrolet 3100 (Ol' Roy)
1939 Packard Standard Eight Coupe (The Phantom) | 1956 Cadillac Coupe de Ville (The Bismarck) | 1956 Cadillac Sixty Special Fleetwood (The Godfather) | 1966 Oldsmobile Toronado (The Purple Knif) | 1966 Ford Mustang (Little Red) | 1964 Ford Galaxie 500 coupe | 1979 Ford F-100 | 1976 Ford F-150 (Big Red) | 1995 Ford F-150 (Newt)
Red #1533941 01/23/2024 9:13 PM
Moderator, Electrical Bay
A replacement spring can be made from the spring inside a common lawn sprinkler head. Just cut it to the length you need. Easy as pie. You can find these at any hardware store and it will be less expensive than finding a true replacement spring...maybe $4 or $5 for an inexpensive head.
~ Jon
Red #1533943 01/23/2024 9:21 PM
There should also be a big flat washer between the spring and the top of the filter cartridge. The standpipe the cartridge slides over has the 1/16" flow restrictor orfice drilled into it- - - -no need to put one in the supply line.
Red #1533954 01/23/2024 9:54 PM
Red
Offline
Thank You
Red
1950 5 Window
Red #1533960 01/23/2024 10:28 PM
Of course I messed up the dimensions. I should know not to trust my memory for this stuff.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.722s Queries: 15 (0.056s) Memory: 0.6158 MB (Peak: 0.6813 MB) Data Comp: Zlib Server Time: 2025-09-22 17:06:18 UTC
Valid HTML 5 and Valid CSS
