0 members (), 151 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#1533622 01/21/2024 5:21 PM
Hello all, I'm restoring my Dad's 1950 3800, so I have a question. Were the wiring harness cloth covered, or rubber wrapped? Thanks in advance...Clint.
My 54 is rubber wrapped and I think the first year for the rubber wrap .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
My '52 (GMC) was cloth.
The harness on my '51 used woven cloth covered wire with vinyl tape wrap, except that the starter to ignition & ammeter and fuel sender to gauge harnesses were covered with woven cloth. I tried to replicate those particular harnesses with woven cloth covering but couldn't couldn't find that individually, so settled on modern plastic mesh covering. Rhode Island Wiring told me that the cloth harness covering is woven on to the harness. They have replacement harnesses for everything on your truck, but $$$$$$. IIRC the 2-wire Starter to Ignition & ammeter harness was $95.
My 51 GMC, one ton/ 250-22 was woven cloth covered. Recommend not going with Rhode Island. There are others out there.
I echo what has already been said: my `51 is cloth covered.
Mike
Livin' the dream; endless searching for parts....
Thanks to all for the replies, really helps a lot!
Little late, but my 53 was, and is rubber, except for the dash cluster wiring. That is a mixture of both.
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
Moderated by  Dusty53
