4 members (Hanks custodian, GMCJammer51, 3B, 1 invisible), 127 guests, and 1 robot.
Topics128,196
Posts1,057,386
Members48,469
i think just brake lights headlights thats it??? did not come from factory with turn sigs or seatbelts.... anyone know???
The equipment it came with from the factory will have to work. Lights, horn, windshield wiper, brakes. Also if you register it as a Antique it does not need to be inspected.
1949 Chevy 6400
1931 Chevy Firetruck
I
I Offline
dont have it inspected as anything but any antique truck, other wise all the stuff must be good, including king pins, tires, brakes, glass, crackes in the frame, exhaust leaks, oil leaks, and sereval other things. A 2 ton falls under federal inspection laws in most states, the less they know the better.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
If you register it as an antique, you cannot legally use it as a truck, carying things, except in a parade. I think that is true in all states.
