| | | Forums66 Topics128,206 Posts1,057,438 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 14 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 14 | Assembling my 235 after I spun a bearing and it seems like it's the pump. | | | | | Joined: Sep 2009 Posts: 6,049 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,049 | bad61, What year 235 are you working on???
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2004 Posts: 29,888 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,888 | The Melling M-45 pump fits later model 235s and 261s from 1955-63 or so. The M-29 fits 216s and 235's without the offset in the passenger's side oil pan rail. Both of them have more than enough volume to keep any healthy engine lubricated. In 65+ years of building engines, I've never seen a non-racing engine that can benefit from a "high volume" oil pump. If the oil pressure is low for some reason, find the worn out bearings and replace them. All that pumping outrageous amounts of oil does is wastes horsepower that could be used to drive the vehicle, and overstress parts like distributor and camshaft gears and shears off pump drives. High oil volume and/or pressure is a solution in search of a problem. Jerry
