2 members (Otto Skorzeny, 1 invisible), 269 guests, and 1 robot.
Topics128,079
Posts1,056,058
Members48,433
Sort of a random question- what size nut will go on the gear shift lever on a sm420? I’m having trouble matching the pitch size and diameter to run a tap to clean the threads.
Could be 5/16-24 or maybe 3/8-24... it's been a while since I've checked one out.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
3/8-24 is the thread count for the shifter knob so that would be correct for the locking nut as well. wink
~ Dan
1951 Chevy 3 window 3100
Thanks. I’ll give that a try.
Worked like a charm! Thanks.
I think you should return the knob and demand your money back wink
Thanks Bill, but I’ll be perfectly happy with this one wink It looks great. Now if it would get a little warmer, I could work on replacing my clutch fork spring. Non-heated barns suck in the winter!
Here's one that puts more of the thread into the shift knob where it belongs- - - -half the thickness of a regular nut:
www.ebay.com/itm/231128874002?
