Topics128,030
Posts1,055,424
Members48,422
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
1959 Chev 3100 w/235 engine. Here's the carb. The # along the bottom appears to be "1022945"? Rochester 1-barrel? Need to know for the correct rebuild kit. Thank you
1959 Chev Napco 4x4 3100 w/235cu
Take a look at this
Tech Tip .
Once you have it identified, there is another tech tip for resolving common issues with them.
The references did not match the numbers along the bottom of the carb? Are you familiar enough with them to identify the pic of mine that I posted?
I think the Rochester's start with 700 or 701 702, then four numbers for the model number.
Like 7003538.
****Ahhh 702 is yours?? See Epay ad. Is that your carburetor?
https://www.ebay.com/itm/145082260843
1950 Chevy 3100
Boy, I don’t think so. Doesn’t quite look like mine. Searching for 7022945 shows a different carb? I’ll need to stare at that carb more I try to identify the number better. Not sure that first # is a 7? I mixed up.
