6 members (Jay R, TUTS 59, Otto Skorzeny, kades51, Cosmo, 1 invisible), 57 guests, and 2 robots.
Topics128,023
Posts1,055,365
Members48,420
#1532540 01/11/2024 6:12 AM
1959 Chev 3100 w/235 engine. Here's the carb. The # along the bottom appears to be "1022945"? Rochester 1-barrel? Need to know for the correct rebuild kit. Thank you
1959 Chev Napco 4x4 3100 w/235cu
3100Apache1959 #1532541 01/11/2024 6:27 AM
Take a look at this Tech Tip.
Once you have it identified, there is another tech tip for resolving common issues with them.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
3100Apache1959 #1532544 01/11/2024 7:00 AM
The references did not match the numbers along the bottom of the carb? Are you familiar enough with them to identify the pic of mine that I posted?
3100Apache1959 #1532545 01/11/2024 7:12 AM
I think the Rochester's start with 700 or 701 702, then four numbers for the model number.
Like 7003538.
****Ahhh 702 is yours?? See Epay ad. Is that your carburetor?
https://www.ebay.com/itm/145082260843
1950 Chevy 3100
3100Apache1959 #1532546 01/11/2024 8:11 AM
Boy, I don’t think so. Doesn’t quite look like mine. Searching for 7022945 shows a different carb? I’ll need to stare at that carb more I try to identify the number better. Not sure that first # is a 7? I mixed up.
