1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
Hello, The "serial number" metal tab on the inside driver's side door jam of my 1949 Chevy Panel truck is : 5GP - E 18016. Can someone decode this? Thanks!
Tom, Your 1949 Panel "serial number" breaks down as:
5 = Kansas City Assembly Plant
GP = 1949 3100 Series (1/2 ton chassis)
E = May (month assembled)
18016 = 17016th truck assembled at the Kansas City plant for that year (the first truck assembled started with serial# 1001)
This information was found using the 1949 Chevrolet Truck Data available from the GM Heritage website. A screenshot of the 1949 serial number info is attached below, but is kinda hard to read. I attached a snap of the 1948 serial number sample info as it is virtually the same as 1949, just easier to read.
~ Dan
1951 Chevy 3 window 3100
Sounds good, thank you sir. But how can mine be the 18th thousand made if they only made 17 thousand...
The first truck was numbered 1001, so truck 18016 is the 17016th truck made.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Oh ok - I get it now. Do you know how many total were made in 49 ? Mine could be the last one made...
I'm surprised. I thought maybe decoding would tell me colors and options...deluxe VS standard etc.
You are at least a decade too early for the engine type to be in the VIN. I have never seen a vehicle that encoded the trim level, colors, options, etc in the serial number.
It is just that. A serial number. In 49 it wasn't even a VIN.
I don't have numbers for total production in 1949, but an LMC catalog I have says that about 41000 1/2 ton GMC trucks were built. I'm pretty sure that far more Chevy trucks were produced than GMCs.
Yep, according to this post there were 201,357 1/2 ton Chevy trucks built in 1949. So yours was far from the last one made.
That and your truck was built in MAY, so yours wasn't even in the middle of the production run.
Yeah, I guess your right . Thanks guys smile
So, I guess there is no way to verify having a deluxe or not...
If we do some simple math we might be able to answer this question.
There were 10 assembly plants in 1949 with about 200k 1/2 ton trucks made total, that makes the average about 20,000 per plant. Your serial number is 17k making it about 3k from the end.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Authorized Pest
Authorized Pest
Originally Posted by Mike B
... If we do some simple math we might be able to answer this question.
Gotta love "simple math." grin
~ Peggy M
1949 Chevrolet 3804
Simple math has a lot of assumptions stacked together. Feel free to tell whatever story you want about where in the line it was, but just keep in the back of your mind that there is no way to actually know.
But the serial number indicates that it was built in May, so there were still up to 7 months to till the end of 1949 yearly production. Since there was a mix of pickup, cowl/cab & chassis, panel, suburban 3100's built, it's possible that his Panel might have been the last one produced in MAY, but NOT in 1949.
Thanks Mike B.
Thanks guys to all of you. I appreciate your feedback.
Just a note, model year production normally ended in late August or September (not all plants shut down at the same date) with the next model year being introduced in October.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
That was true later (80s+), but had they started that trend in the 40s/50s? It was my understanding that they had not.
1936 model cars and trucks were introduced on October 1st 1935. I believe this was the first year Chevrolet made the change. The 1935 models were introduced in January 1935 making it a 9 month model year.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
