1 members (Wayne67vert),
96
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 2,244 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,244 | I have the heat riser removed at the moment because I am working on the exhaust. I wire brushed the built up carbon off all of the surfaces.
It currently moves smoothly and opens and closes with engine heat as it should.
Is there anything other than cleaning I should do to it while it is out and accessible? | | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | I use powdered graphite in the squeeze tube that's usually used to lubricate lock cylinders, and squirt a little on the pivot points where the shaft goes through the exhaust manifold. The powder won't burn and gum up like grease-based lubricants do. www.ebay.com/itm/295947541184?Jerry
| | | | | Joined: Jan 2019 Posts: 2,244 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,244 | Thanks Jerry, I have a couple tubes on the shelf and will give it a few shots. | | | | | Joined: Mar 2014 Posts: 4,523 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,523 | As Jerry said, graphite is good. What I've learned about these is if the vehicle is driven regularly, there will generally never be a problem. It is when the thing sits there and humidity/rust set in that it fails to work.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Does copper anti-seize work under that kind of heat? Not sure what the carrier is that suspends the copper flakes.
1951 3100
| | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | As I said, any grease-based lube around a heat riser isn't a good idea. I have monitored exhaust gas temps at cylinder head ports in the 2K degree F. range on a hard dyno pull. I don't know of any lube that will stay put when a cast iron manifold approaches a dull red color, but dry graphite has a better chance of it than any liquid or paste. Jerry
