5 members (TooMany2count, fonz8261, Peggy M, TexasJim50, Chip O), 65 guests, and 1 robot.
Topics128,033
Posts1,055,531
Members48,425
#1531151 12/31/2023 7:01 PM
2 Offline
I made the crossover line for the rear brakes (right side) this morning took me about an hour and a half carefully bending and test fitting, what a pia! I was determined to get it over the top , it was 50/50 top or bottom route. I found that a 1/2" deep socket works well for the tight bends at the ends thumbs_up
1956 Chevy 6100 with a dump box
Story in Big Bolts
1949 ford 8n tractor
1958 861 diesel ford tractor
2003 honda vtx 1800 c bike
7
7 Offline
Very nice job!
They do make a tube bender for the small 3/16TH lines, it makes very nice tight bends. I am always afraid to kink the line using anything else.
1936 GMC T-14 restro-mod
2 Offline
Thanks buckshot it was worth the effort 👌
Story in Big Bolts
FAST55 #1531200 01/01/2024 12:27 AM
2 Offline
Fast I did use my tubing bender for some of it but the ends were the tricky part, you have to tweak them a bit that's where the socket came in handy.
Story in Big Bolts
Wont you run the rick of trapping air with the line going over the hub instead of under making it hard to bleed?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
2 Offline
The original route was over the top so that's what I did, DougH6100 ran his on the bottom which should pose no issues. His brake line and mine have far less drastic bends, that's why I say it's 50/50 ether way . Ether way air is forced downhill in my opinion thinking
Story in Big Bolts
