| | | Forums66 Topics128,082 Posts1,056,303 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Howdy Folks, does any one know of any...? I could use a replacement for my 49 Chevy Panel truck.
| | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | What are you using for phone charger ?  | | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | Rubber black plug. Weld it closed. Use it for some other switch hole for something else you want to do. Convert to usb charger. Lots of options. | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | It has one, (delete cover), but it looks copper colored and scratched-up. I want to stay old-school with this one...
| | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | The Filling Station has them. I'm pretty sure it's 3/4 inch diameter, but they have other sizes as well. Link
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Hi there, I checked out their website, but they are a little too modern looking for what I'm looking for... | | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | The one that was in my truck was painted, which you could do with that Filling Station one. Other than the nickle plating it looks pretty dang close to the one on my truck.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Cabinet knock-out plugs can be found in all different sized at Ace Hardware...scuff it up and paint it to match. Mike B
