6 members (Tom McGrath, 32Fordpuchoptop, Otto Skorzeny, Gdads51, Wickedbass, 1 invisible), 94 guests, and 2 robots.
Topics128,094
Posts1,056,051
Members48,433
#1530746 12/28/2023 12:19 AM
GETTING READY TO BLEED THE BRAKES ON THE '36. IT;S A DISC/DRUM RESTRO MOD. SHOULD I USE DOT 3,4 OR 5 SYNTHECIC? IT'S NOT READY TO BE DRIVEN JUST YET, BUT WILL BE SHORTLY.
1936 GMC T-14 restro-mod
FAST55 #1530748 12/28/2023 12:40 AM
O Online: Content
What fluid is in it now? If it isn't DOT 5, you'll have to flush the entire system with alcohol before filling with DOT 5.
DOT 3, DOT 4, and DOT 5.1 are compatible with each other.
DOT 5 is 100% silicone and cannot be mixed with the others. If you have anti-lock brakes you cannot use DOT 5.
Are you drag racing it or auto-crossing in it? If not you really won't have a need for DOT 5.
1950 Chevrolet 3100 (Ol' Roy)
FAST55 #1530793 12/28/2023 4:46 PM
The system is virgin right now, No it's just a street cruiser, run to the store or the parts house. Just thought dot 5 would be better for a truck that's not driven every day or in rainy weather. So sounds like dot 4 it is.
FAST55 #1530813 12/28/2023 8:36 PM
H Online: Content
Use dot 3, iirc it absorbs less moisture….not as high performance but neither are we, need to change it less often…….
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
FAST55 #1530816 12/28/2023 9:11 PM
I use DOT 3 on all my antique autos including my 46 GMC. Do a web search and you will see why.
1946 with WWII 270
FAST55 #1530827 12/28/2023 11:27 PM
OK DOT3 it is.
FAST55 #1530837 12/29/2023 12:26 AM
At the end of the day, it is your call based on what you want. Any of those choices will function fine and be safe.
I personally went with DOT3 when I replaced my entire brake system this fall because it is cheap, readily available, absorbs the least water, and has more performance than I need.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
