Topics128,149
Posts1,056,814
Members48,454
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Is it OK to shim the inner fender well away from the cab? Somehow after trial fitment its the only way to get my gaps correct?
My guess would be yes. I wouldn't be surprised if that happened at the factory a time or two. But I'm not familiar with the 66 trucks.
1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car)
I also had to shim my 62-c30 out to get it close. That was more than they did at the factory
1962 c 30 ginpole was Dad's first new truck 261 with a 235 head due to a crack. 4 speed
I didn't on it my '66, but I would if I needed to.
I will throw some shims in there and see what it looks like. May need to seam seal around the top.
