7 members (rfs56trk, Gray_Ghost, Wally / Montana, walter74, MRMEROTH11, David Bush, 1 invisible), 67 guests, and 3 robots.
Topics128,056
Posts1,055,803
#1529101 12/10/2023 9:09 PM
Does anyone know where or who is making reproduction torque tube ball and flange. Thanks in advance
Jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
I don’t think they make reproduction ones ,check e bay or put what you need in the parts wanted section .What is wrong with yours ,l welded and filed mine to fix the grooves.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Got a couple, I'm pretty sure. Does anyone know if the ball is the same on a Powerglide automatic? I think it is.
The speed is the same as the one from the 4 speed I have ,don’t know about the automatic.
"The Journey"
Follow in the DITY
I have a spare off of my '54. There is a slight deformity at the edge of the ball caused by me pounding to separate the torque tube from the trans ("stupid is what stupid does"). It appears that it would not effect the functioning ...but, I am not the one to judge that. I tried to show in the photos.
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system.
JB Weld..."I put that stuff on everything"
Not sure if I'm actually going to need one. Just trying to be proactive
