1 members (klhansen ),
101
robot. Key: Admin ,
Global Mod ,
Mod
Topics128,151
Posts1,056,999
Members48,460
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
1950 Chevy 3100 216 3 Speed.
What is the difference between the two Rochester carburetors?
Darren Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
Moderator, Electrical Bay
The ones on the left are newer style…possibly for a 230 or 250 engine. This type used an air cleaner with a central screw. The ones on the right are the old style model B…for 216 or 235 most likely.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
1st design with smaller air horn / clamp on air cleaner, thru 1959. 2nd design on the left has larger air horn / center stud air cleaner attachment. 2nd design used from 1960 - 1967, replaced. In '68 by mono jet.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022
Riding in the Passing Lane
That choke/throttle cable bracket on the carb on the right is worth more then the carb itself. Don't let it get away. George
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne Super In the Gallery Forum
It’s worth more than all 4 of them together.
1951 3100
Are you guys serious about the bracket? It is that a running joke Because I’ve never seen a shortage of them up in Canada Every old carb has one I have about 20 on my farm -s
Carburetion specialist
NOW we know who has been hoarding them!
Jon
Good carburetion is fuelish hot air The most expensive carburetor is the wrong one you attempt to modify.
If you truly believe "one size fits all," try walking a mile in your spouse's shoes! The Carburetor Shop
It may be somewhat of an exaggeration but they are scarce & worth some $$ here in the States. George
