4 members (kbenz, cmayna, Cletus1950, 1955 1 Series), 94 guests, and 1 robot.
Topics128,156
Posts1,056,871
Members48,456
#1528170 12/02/2023 6:20 AM
Does anyone know if the exhaust y-pipe is the same for a GMC 288 thru GMC 336? I’m restoring a 1958 GMC NAPCO truck back to original condition and I’m keeping the single exhaust. The left and right manifolds dump into a y-pipe that has a collector on the right where the exhaust pipe attaches. I think it’s 2” O.D. pipe. Just wondering if flange angles on Y-pipe match angles on manifolds 288-336. Waldron Exhaust has a kit for ‘57 GMC but don’t know if it will bolt to my 336? Any help appreciated.
Regards,
Craig
1953 3100 | 1958 3/4-ton NAPCO
GMC did you no favors. Below is the list of GMC exhaust pipes from 55.2 (Y series), 56 (X series), 57 (T series), 58-59 (S series V8 engine serial number below 336-35000 [engine based on 58 Pontiac 370] and above 335-35001 [based on 59 Pontiac 389]). I'm assuming the "front" pipe is the Y pipe from both manifolds to the front of the muffler. Mine had been "dualed out" before I bought it in 1990.
