4 members (Rick Brown, DadsFirstPickup, Robert Crandall, JakeM), 128 guests, and 1 robot.
Topics128,108
Posts1,056,239
Members48,437
‘49 Chevy 3800. Has the fresh air heater. The heater has water inlet and outlet, water pump and thermostat housing has outlets and the heater valve has inlet and outlet. My question is how is all of this plumbed together. Truck came to me with all of this unhooked and I’ve searched high and low for the diagram but no luck. Can someone please provide a schematic for hooking all this up? Thanks much!
1949 Chev 3800
The coolant can flow either way through the heater core. Flow direction is out of the thermostat housing to the heater core, and the return line goes to the water pump. If there is a cable controlled valve regulating coolant flow through the heater, it's usually better to plumb the "pressure" hose from the thermostat housing to the valve.
Jerry's right about the heater core flow can be in either direction. But it might be better to connect the return hose to the highest port on the heater core to be sure that any air in the core gets purged out and back to the engine. There may be enough flow to flush air in either direction, but it doesn't hurt to help it along. I think Brad Allen has the installation diagram in his photo collection. I'll see if I can track it down.
[on edit] I looked thru Brad's Flikr account, but didn't find the heater install instructions. Too many photos to look thru, and get distracted. If you need something to do (insomnia?) I'd recommend browsing thru his stuff.Should be somewhere in this album.
Thanks to both of you for the tips!
1949 Chev 3800
Thanks much klhansen. Went through the album and found a picture of just what I needed! Big help! D
1949 Chev 3800
Do you remember how many pages in that was? I'd like to see it also, but didn't get that far in.
Professional procrastinator
There is a pic near the end of the first page which shows routing.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
Thanks, I saw that, but I was looking for the installation instructions for the heater. I recall seeing a document posted that showed that. I'm sure it's around here somewhere. I could have sworn Brad was the one that posted it. ohwell
Kevin, Is this the thread that included pics from Brad? wink Here is the 1951 instructions main diagram. The actual written instructions start 2 pages back.
I took a gander and "Brad's" photo album - WOW! After an hour, I hadn't even scratched the surface. Thanks for sharing that info! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Dan,
That link that bowtietim posted (and you duplicating above) was what I was thinking about. Yes, Brad's collection is pretty awesome.
Again, you earned that "Parts Tracker" handle. smile
