0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#1526876 11/22/2023 12:38 AM
I installed a new wiring harness in my truck and found out the guage wasn’t supported in that version.
I’ve checked and it is charging like it should just no guage.
Is there a way to hook it up so it will read like it should.
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T-Doug #1526878 11/22/2023 12:52 AM
B Online: Content
Originally, the + side of the ammeter only connected to two places, the battery + cable (at the stomp starter switch) and the horn switch. The - side of the ammeter connected to everything else.
How to go about integrating the original ammeter into your replacement harness would require intimate knowledge of your new harness.
T-Doug #1526883 11/22/2023 1:26 AM
If you are handy with electrical things, it isn't terribly complicated.
What you need to do is identify the battey feed for your new harness and put the ammeter in series with it so all of the electricty flowing in and out of the battery goes through it.
If that explanation is not sufficient for you, I would recommend getting some hands-on help because you can make a real mess and cause significant issues if you don't hook it up properly.
That assumes that you have not upgraded to a high output alternator or high-current accessories. If you have, the ammeter might not be able to safely operate. I have never seen a solid, documentes number for the max current on those ammeters. If anyone has one, I would be quite interested in its source.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
