0 members (),
79
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 117 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 117 | Got a weird situation going on and I need some input from ya'll. '50 3100, 6 volt system, all new wiring, new VR, new coil, new points/condenser. The truck had been running well with no issues of an electrical nature. Now, it has developed this issue: whether at idle or at higher RPM, the ignition will drop out momentarily, like it just skips a beat, then pick back up. I can tell it is electrical because the fuel gauge will drop and then recover every time the engine stumbles. I thought it might be the coil, so it has been replaced--no change. Then I replaced the condenser with no change. Battery voltage is right up there, all grounds have been checked, generator is putting out good voltage. I'm at my wits end as to what this may be. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The gas gauge does not depend on the engine running or missing. It is direct wired from the ignition switch. So seems like a ignition switch issue. It is cutting off power intermittently to gauge and coil. Gas gauge and coil are on the same ignition switch terminal per wiring diagram. Check wires at that terminal. If wires and terminals are tight, then probably the switch is acting up. If there is an unused terminal, try using that one for those wires. if you have the original switch, it has three terminals. Does not matter which terminal is used for what. They are all off or all on. Just so the terminal used from the ammeter has no other wire on it. It could also be a similar ignition switch/wiring issue. Switch losing power from the Ammeter. (basically direct battery power)
More can be learned if we know what else goes off besides the motor and the gas gauge. I.E. lights, what the ammeter does, any other electrical gauges, radio, heater blower......
EDIT: if we find out everything is going dead momentarily, we will list more areas to check including the battery and it's grounds.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2022 Posts: 117 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 117 | I was so focused on watching the gas gauge that I did not think to turn the lights on to see if they were affected. Tomorrow I will fire up and see what the lights and ammeter do; there is no radio or heater. I had considered the ignition switch, since it is original to the truck. Will check that out tomorrow. | | | | | Joined: Mar 2014 Posts: 4,480 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,480 | Headlights might be a miner's canary for you here. They are not wired through your ignition switch so if the switch is intermittently cutting power off to your coil, etc your headlights won't show any flicker when that happens. Good luck!
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | A generator will keep the system running even if the battery is disconnected for a second So it likely isn’t a battery issue nor a headlight circuit issue Assuming the generator is working So the problem is most likely where Bartamos suggested Between key switch and coil -a | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | If the headlights get dim while the misfire is going on, you probably have a loose wire coming off of the ammeter. That happened to me once. Some dill weed mechanic didn't tighten the nut on the ammeter. I would have fired him on the spot, but since I am a one man operation, I had no one to fire...
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Look for bare wires in places where they go through sheet metal panels. An intermittent short can cause the lights to flicker, and interrupt the ignition circuit at the same time. Jerry
| | | | | Joined: Jan 2022 Posts: 117 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 117 | Well folks, I think we found the gremlin (not the one from AMC) that was causing the problem. Bartamos nailed it from the get-go. I went under the dash and swapped the wires from the I terminal over to the A terminal on the ignition switch and she has not missed a lick since. Cranks better, runs smoother. I just assumed that since the switch had been good for 73 years, it ought to still be good. Rest assured, there will be a new one under the dash ASAP. Thanks to all who responded and woke me up to the potential weak spot in the chain. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | The lugs on the ignition switch are held on by rivets. They get loose of time.
| | | | | Joined: Jan 2022 Posts: 117 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 117 | Another dive under the dash and replaced the 73 year-old ignition switch and cylinder. Just not taking any chances on using that old piece of equipment. Now on to trying to find out why the VR will not let the genny do its thing. | | |
