4 members (Shardean, Peggy M, klhansen, Eisenholtz), 50 guests, and 5 robots.
Topics128,022
Posts1,055,376
Members48,420
#1525522 11/11/2023 4:32 PM
Pulling the cab for better access,replacement of bolts and wood blocks some welding etc. these rear cab spacers seem to have seen their better days. I haven’t seen them available. What have others done? If home made..how? Or a source?
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
37 GC #1525553 11/11/2023 7:48 PM
Blocks of hard maple will last about 3 days past forever. Turn them round on a wood lathe if necessary for clearance. Use rubber washers made from a big truck tire sidewall if you want a little cushioning.
37 GC #1525563 11/11/2023 8:51 PM
thumbs_up
37 GC #1525678 11/12/2023 5:48 PM
Thanks hot rod! I think that’s probably what I will do, they do have those spacers in the $157 kit, but my springs were fine and some nice new long bolts cost me around $10. The old ones had seen their day. Although I’m trying to keep my 37 reasonably original I will be deviating With something like this. To stay a little bit more original in appearance I think I will turn a piece of maple to slip into a piece of inch and 1/2 OD galvanized pipe.
Larry
