2 members (KEVINSKI, crenwelge), 108 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
#1524741 11/06/2023 3:14 AM
Crusing in the Passing Lane
Use of a small link makes changing hood springs a snap.
Ed
AD Addict & Tinkerer
Great tip, I didn’t take mine off for fear of not getting them back on. Thanks!
Phil
Project Journals
Stovebolt Gallery Forum
With a come along? No thanks. The spring hook tool works fine for me between $7 and $15.
Grit your teeth or stick out your tongue and get the job done.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Ed,
Thanks for the tip! thumbs_up
Guessing the pictured truck is your 1955 2nd Series GMC???
An interesting option, especially for those that may have back issues (me) that threaten to put you down for the count if one overdoes the pulling (I speak from long experience).
Your tip I think better fits into the Paint and Body Shop, so the thread has been moved there for further sharing and conversation.
~ Dan
1951 Chevy 3 window 3100
D Online: Content
All kinds of videos on YouTube for removing/installing hinge springs. Some are very creative if you need some mechanical help to stretch them. Like using a hydraulic floor jack.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
A quick and easy trick I've used for a lot of years involves a handful of big flat washers inserted between the coils of the spring to keep it stretched. On a new spring, just clamp one end into a vise, bend the coils sideways, and insert washers into the gap created by bending the spring. It's easier and safer than trying to stretch the spring out.
To do it manually, tie a piece of parachute cord to a solid point in line with where you need to hook the spring, loop it over the spring eye and pull back toward the tie point. With the 2-part line, you only need to pull half of the spring strength.
Jerry, I'd be afraid of having a stack of washers being spit out of the spring. big_eek That'd be just my luck.
I'm wondering if something similar to a brake tool, if not the very same tool, would work in this situation.
I forgot to mention using a thin piece of dowel rod like a grilling skewer through the middle of the spring to keep the washers in place.
Yeah, a pin in the grenade would be good. thumbs_up
Riding in the Passing Lane
Ive used the washer way for many years. It is probably the safest way. I put on end hook in the vise & push it over. Put thick washers in between each coil. Then bend it the other way & put washers on the opposite side. Hook the elongated spring on the hood & put the hood down. All the washers will fall out.
George
1972 Chevy c10 Cheyenne Super
You just have to make sure all the washers find their way to the floor.
I used to could do it by myself with a "J" hook. Still can,
I just get my son in law to push the spring on the catch with a 1x2 wood pole from the other side.
~ BD.
