| | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2015 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 84 | 1959 ish 261 . Has the full flow button on the engine side. Don’t even ask why I pushed it in…. Well the pushed in button gives full flow out the threaded port for an oil filter. Problem is I’m not ready for that yet. Also my quick fix hydraulic hose port to port is probably too small diameter. As the engine seems to be starving for oil under load. Question . How do I pull the button back out . Thanks | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Drill and tap it if you can ( I don't think it's hardened) and use a long bolt or a piece of all thread, a nut and a flat washer, and a deep socket to pull it back to the original position. A 3/8-24 thread should work OK. The line connecting the two ports needs to be 1/2" inside diameter if you aren't running a full flow filter. Jerry
| | | | | Joined: Nov 2015 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 84 | Thanks. How long is the plug ? Can I drill a half inch in safely ? | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Yes, I think so. If I were going to fool with doing a full flow conversion, I'd pull the plug all the way out and thread the block for a screw-in bolt instead of the press fit plug, but that requires a complete teardown to a bare block to keep cast iron chips from contaminating the oil passages.
The "full flow" concept is a giant leap backwards in oil filtering. Running a filter with a loose enough weave to flow all the oil volume needed to keep the bearings lubed means none of the oil gets filtered efficiently. Like Carter used to say about fuel filters, the average fuel strainer is there to catch "rocks, marbles, and bowling balls". The same can be said about full flow oil filters. A 1-micron hydraulic oil filter in a "bypass" configuration will do a good job of keeping motor oil clean, but it won't flow enough volume to keep the engine lubricated. Jerry
