0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | In a 1950 3100 3spd pickup I needing to know if the transmission is a Muncie 318 or 319.
1950 chevy shortbed 3100, 216 with a 3 on the tree.
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | A 1950 3 speed is a 318. A 319 is a 55 to 65 overdrive. GM did a good job of confusing the issue. 48 through 54 3 speeds are called SM318's as well as the 55 through 67 open driveline transmissions even though they are nothing alike. Fred
