| | | Forums66 Topics128,180 Posts1,057,149 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 2,422 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,422 | Interesting article in the 12 Port News (Inliners International). The article is about the hydraulic lifters of today being much better than those that were produced years ago. Still not as good as solids for full blown race applications, but some are using them for that purpose. Lots of details mentioned along with websites for several camshaft and lifter manufacturers.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Hydraulic lifters in a stovebolt engine are a solution in search of a problem unless it's too difficult to get access to the rocker arms to do a valve adjustment, like a cabover, for instance. Jerry
| | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | Conceptually I would agree with that article, but getting good quality hydraulic lifters that function out of the box has been a real challenge the last few years.
Even the "good" brands are shipping a lot of DOA parts. | | | | | Joined: Nov 2004 Posts: 2,422 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,422 | Four camshaft mfg’s were listed, but Rhoads was the only lifter brand mentioned in the article. Maybe Rhoads are better than their competition?
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | Worth a look. I don't think I have any personal experience with them. Is the article available online somewhere for review? | | | | | Joined: Mar 2007 Posts: 3,446 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,446 | I have used Roades lifter on several engine build with great success. They prime easily and provide great vacuum, I haven't had a lifter failure yet.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | The only Rhoades lifters I'm familiar with are the ones that have a rapid leakdown rate at low speed. That serves to allow a pretty radical cam to be used and still maintain pretty good manifold vacuum and a smoother idle due to less than complete valve duration and lift at idle and low speed. Once the oil flow to the lifters increases as the engine speed goes up, the full range of the cam lobes comes into play. They're definitely not for everyday street use. It might be possible that Rhoades makes a conventional hydraulic lifter, but I'm not familiar with them. Jerry
| | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | Jerry, I got a copy of the article and it describes that feature of the Rhodes lifters. It calls them "variable lift and duration" lifters.
Interesting idea, but I agree that I don't think I would want them in a street engine.
Overall, interesting read. | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Let’s be clear. New lifters for the 235/261 chevy are not better than the older USA made lifters. Not by a long shot. The problem with the new manufactured hydraulic lifters for 56-62 235 motors is with the design, spring and metallurgy. They simply will not do the job with any kind of reliability. Collapsing, sometimes within minutes of starting a motor for the first time, bad machining, bad crown, poor oil control design. They are not a copy of the original and do not perform as well either.
This has been going on for quite a few years now. Real Gm lifters are made from superior materials and engineering. In the 47 years I have been playing with the 235 and 261 chevy motor, I have never had a cam/lifter failure when using GM lifters and follow the appropriate pre lube and brake in procedures to the letter. A pretty close second is USA made lifters. But these lifters have to actually be made in the USA and generally need to be like 30 years or more old.
So while I read that article with great interest, it is not applicable to a Stovebolt lifter.
Mike
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Solve the problem the easy way- - - -use AMC/MOPAR/Ford hydraulic lifters. There are plenty of USA made new old stock lifters of that series. They're all the same diameter and height, and it's easy to adapt them to a stovebolt block. Jerry
| | | | | Joined: Feb 2019 Posts: 4,510 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,510 | Solve the problem the easy way- - - -use AMC/MOPAR/Ford hydraulic lifters. There are plenty of USA made new old stock lifters of that series. They're all the same diameter and height, and it's easy to adapt them to a stovebolt block. Jerry Oh, Jerry, please do tell!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | I sleeve the stovebolt lifter bores down a few thousandths and finish the diameter with a piloted chucking reamer and a button wheel cylinder hone to get the correct sliding fit. The MOPAR/AMC/Ford engines all use the same part number lifters, and they're plentiful and dirt cheap. The lower end of the stovebolt pushrod needs to be adapted to a 5/16" diameter ball end to mate with the lifter. That's done by cutting the original end off the stovebolt pushrod, pressing a sleeve over the cutoff end, and pressing a short section of a ball end pushrod into the sleeve. Schneider cams is about to regrind some steel core 216 cams for MOPAR roller lifters for me, to go into my Frankenstein engine with roller rockers and roller lifters. Jerry
