2 members (78buckshot, NJC), 99 guests, and 3 robots.
Topics128,149
Posts1,056,819
Members48,456
#1523386 10/25/2023 2:54 AM
I’ve discovered that my 235’s oil pan has a LOT of sludge in it and I’m preparing to pull the pan, clean it out and reseal with a new oil pan gasket. While I’m in there I want to clean out the screen on the oil pickup tube. Is there a way to remove just the screen? If not, what components will I need to remove in order to ensure the pickup assembly will work properly and be clean. Thank you.
A running engine flush will clean out a lot more sludge than a manual scrubbing- - - -no need to remove the pan unless you're planning to fix a leaky pan gasket at the same time. Overfill the engine with Kerosene or Diesel fuel- - - -3 quarts or so added to a full fill of oil, and run the engine at a fast idle for 20-30 minutes- - - -about 1500 RPM or so. DO NOT DRIVE THE VEHICLE OR PUT ANY LOAD ON THE ENGINE! Drain the oil/solvent mix while it's hot, and virtually all the sludge will go with it. The crankshaft and connecting rods dipping down into the high liquid level will splash it around like the agitator in a washing machine.
A 235 has a pickup bolted to one of the main bearing caps, with a tube from it to the pump. You can remove the pickup screen and tube by simply unbolting it and disconnecting the line from the pump. I have fabricated a new strainer screen to replace a rusted or damaged one from fine mesh stainless steel screen available on Ebay Just fold the screen into the right shape and pop rivet it to the sheet metal pickup housing.
What year motor is this if I may ask?
Mike
1955 first series 235
Ahhh. If it had been a 58 or 59-62 I might have a nos spare pickup but no dice on the early 55 motor.
Mike
If you're planning to fabricate a new strainer, here's some material that's approximately the right mesh size, and stainless. It ought to last about three days past forever.
www.ebay.com/itm/285175857026?
Thank you
