1 members (Otto Skorzeny),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2023 Posts: 5 'Bolter | | 'Bolter Joined: Oct 2023 Posts: 5 | Can anyone tell me the correct size or where I can get the correct hinge pins for the rear barn doors...I have seen some in the catalogs with brass bushings and I don't see a way to install them also they are flat on the end and shorter that the old pins. The old pins have a point on the end and protrude below the bottom of the hinge. 1948 chevy 1/2 ton panel.
Thanks | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | Did you try Filling Station in Oregon? Or Chevs of the 40s in Washington? | | | | | Joined: May 2015 Posts: 11,138 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,138 | Jim Carter has oversize pins that are overlong, so you could cut and shape the end however you wanted. But i think they're designed for the concealed pins for the front doors. You might also try Restoration Specialties, but would have to call them to get the correct ones, as their website doesn't give you much info. Link
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2023 Posts: 5 'Bolter | | 'Bolter Joined: Oct 2023 Posts: 5 | I purchased some from Chev's of the 40's and they are not correct, I will try filling station. Thanks for info | | | | | Joined: Oct 2023 Posts: 5 'Bolter | | 'Bolter Joined: Oct 2023 Posts: 5 | Thanks for info, I will give them a try | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | I can fix your old hinges if you aren't able to find something suitable from the resto-ripoff places. Send me a PM. Jerry
