8 members (Guitplayer, 78buckshot, Otto Skorzeny, cmayna, Cletus1950, Southerntruck, 1955 1 Series, Wayne67vert),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,156 Posts1,056,871 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2023 Posts: 45 'Bolter | | 'Bolter Joined: Sep 2023 Posts: 45 | I have a 55 first series 3100 chevy truck and am planning to install a n early sixties C-10 6 lug rear end in order to get a high gear ratio. I don’t have the original rear end that came with the truck so I can’t use those original leaf spring perches. Where can I get some new perches to weld on the replacement rear end that I will be installing? Thanks in advance for the feedback and assistance. | | | | | Joined: Feb 2023 Posts: 103 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 103 | Most vendors will have the saddles to mount your new rear end. Classic Parts lists a complete "Rear axle conversion kit" including mounts, u-bolts and shock mounts part number 93-311 that will work for a 55 first series
1954 Chevy 1300 engine 235 (1959) 1955 (first series) Chevy 3100 engine 261 (1957) 1927 (other brand) Model T- engine 327 (1968)
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I don't think you will gain much going to an early 60's rear end. It probably has a 3:90 ratio & yours is probably 4:10. I don't know what engine you have but some of the 67-72 c10's had 3:08. They may be to wide for your 55 & i'm not sure the original engine will pull it. What about changing to the the gears in yours to the 3;55 gear set?
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2023 Posts: 45 'Bolter | | 'Bolter Joined: Sep 2023 Posts: 45 | Thank you. Where could I pick up some quality 3:55 gears? | | | | | Joined: Mar 2014 Posts: 4,505 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,505 | Hi and welcome to the site! The late 60s C10 trucks were great for the AD pickups. Just the right width. Many of those had ratios starting at 3:07 (which is what I have). Mine was out of a 1969 C10 which had been a really nice truck before somebody decided to drive it upside down. You can even use the same emergency brake setup simply by modifying things a wee bit. If by chance you're swapping the transmission to the T5 look for the T5 which has the gear chain beginning with 4.03 and you'll have an overall first gear ratio of 12.08 and that will let you still use your pickup as a genuine pickup (the first 3 gears will feel exactly like the original setup) plus drive at 60 mph at around 2000 rpm, 65 at 2100 rpm, etc. You'll need to cut off the coil spring mounts the late 60s C10 trucks came with, discard the panhard bar, smooth the axle and use any generic spring perch piece (or you can use the round adjustable collar like I did and weld when you get your pinion angle correct. You'll even get to use the same brake line hookup and wheels. When you're welding those perches, just use common sense and weld 1/2 inch or so on one side then move to the other side while it cools, return and keep that up so you don't risk warping the housing (which I've seen people do by just running a solid bead). Easy work if you can find one. Good luck!
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | you can use the round adjustable collar like I did and weld when you get your pinion angle correct. I have done a few axles now with perches from the trailer supply shop, but I am not familiar with what you are describing here. Can you elaborate or give us a link? | | | | | Joined: Mar 2014 Posts: 4,505 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,505 | Like this: https://www.amazon.com/Clamp-On-Leaf-Spring-Mount-Pad/dp/B01N9VQ6BQMakes the work of setting, adjusting, re-adjusting, etc a lot easier. And as far as welding you can just weld the southern hemisphere of the mount if you think you might want to adjust your pinion angle later. That gives you plenty of strength.
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | Those are pretty cool. Thanks! | | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | I looked on Speedway's site and didn't find them. I'll bet that someone used them and didn't weld to the axle and spun the axle housing. They probably discontinued them to protect themselves from the dumb___s who don't install them correctly.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2014 Posts: 4,505 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,505 | https://tinyurl.com/yp8ks7bhAbove is a link to them on Speedway's site. Actually Speedway is one of the companies who sells them branded under their own name (Speedway Motors). Nearly everyone sells them and they've been available for around 40 years. The instructions you get with these are very clear about welding them before using them. Not to say some nitwit didn't just clamp them on and go. It is impossible to predict nitwits. Several years ago a friend used silver bearing solder to attach these to his axle (that solder as I've mentioned here numerous times will work fine with ferrous metals as long as you understand the principle of cleaning and fluxing). I asked him a couple of years ago and he said they were still doing fine...no problems. Most silver bearing solder has a tensile strength of something over 10,000 PSI (some as much as 18,000) and as you can see there are several square inches of metal to use in this case. You can also braze them in place if you can use an oxy-acetylene rig, but you do have to heat things up more that way. Silver bearing solder melts/flows at a mere 450 degrees. Good luck!
| | | | | Joined: Aug 2005 Posts: 125 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 125 | I assume the 55 first had a closed driveline? If so, what transmission is being used with this 60"s rear axle? | | | | | Joined: Feb 2023 Posts: 103 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 103 | If it is a 1955 first series it came with an open driveshaft, one of the few differences from 1954/
