5 members (RLB, Guitplayer, Otto Skorzeny, carbking, 78buckshot), 148 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#1521545 10/12/2023 4:13 PM
Seems we only get to work on this project every now and again…
But so it goes with projects..🤷‍♂️
Anyhow, freed up stuck oil pump from our 302 that had been sittin for a number of years.
Got a replacement camshaft and went press gear off of old cam and broke the gear.
Didn’t realize it was aluminum, seemed like removing it on a shop press was the best method,,,, not so much.
Casting # is 2194906
Looking online for another cam gear and not finding any I feel are the exact same ?
Any suggestions ?
Brian
1952 GMC model 473 dump truck
1951 Chevy 1500 stepside
I believe the same cam gear that fits a Chevy six will work. The cam gear that fits a Mercruiser 4 cylinder is also a close match to the Chevy- - - -it might need a little machining in the hub area to match up with the thrust plate correctly. New Mercruiser gears are dirt cheap on Ebay.
Jerry says it may work, but definitely not the same part number. Chevy aluminum gear is 3835473, GMC is 2194906.
It would probably be necessary to compare the remains of the broken gear to a Chevy item, especially the position of the keyway and the timing marks. Diameter and tooth count would need to be exact, other details could be massaged if necessary.
1950 Chevy 3100
According to the Hollander Manual the chevy 3835473 Al and 3836156 Fb interchange with GMC 2194906.
Originally Posted by Shaffer's1950
Scroll down the ePay page and there are two more for less $$.
I'd trust Hollander on this.
For future reference, use a bearing splitter to spread the load over a wider surface of the gear when pressing it off. I consider stovebolt timing gears to be a one time installation piece- - - -it's risky to try to reuse one that's been installed before. The timing gear I'm going to use on my roller cam engine will be honed to be a snug slip fit and retained with a bolt and a heavy flat washer, since I'm planning to tinker with the cam timing with offset Woodruff keys.
I thought about the bearing splitter. But there really wasn’t any room between cam retainer plate and gear.
Was pressed on there pretty tightly… but I’m sure more experienced bolsters may have had better luck and gotten it off.
Looks like maybe 50$ or so … so not bad
