| | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2016 Posts: 177 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 177 | Finally got the crankshaft out of the '54 235. Low and behold, the camshaft nor the pistons were stuck and neither were the gears. It was the crankshaft itself! It took ALL my weight ( believe me, that's considerable!!!) of bouncing up and down on a heavy duty pry bar to break it loose. So anyway, took it in to be sent off for resurfacing (crankshaft) and started searching for main and rod bearings. Considering the prices of the main bearings ($200 - $330), is there a difference in quality between TwilightZone, Napa, Jim Carter, Chevs of the 40s, etc? Hotrod suggested "SBC 400" in another thread, but who carries those or do I not understand that conversation? Any and all responses will be appreciated ($60 for a set of mains?).
SS Stewart2 1955.1 3100 Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC Jack of several trades and experiences; Master of none
| | | | | Joined: Feb 2004 Posts: 29,848 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,848 | You really don't want to go with the conversion to a different size bearing such as the SBC 400- - - -that's a project for professional machinists with decades of experience and access to lots of expensive machine tools. Let the machinist who regrinds the crankshaft source rod and main bearings- - - -if he drops the ball, it's on him to make it right. Be sure to get the connecting rods reconditioned when the rest of the machine work is done. Main bearings for the 54 and early 55 235 engines with the dowel pins in the upper bearings are extremely scarce, and expensive. It's possible to modify the engine block to accept the later model main bearings that are more plentiful and less expensive, but it's not a job a shade tree wrench jockey should attempt.
Did you loosen the main bearing caps before putting all that force on the crankshaft? That's "engine disassembly 101". Jerry
| | | | | Joined: Dec 2016 Posts: 177 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 177 | Stewart2 1955.1 3100 Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC Jack of several trades and experiences; Master of none
